I Have the same issue on a Huawei P30 pro.
Android 10 High-Urgency Override System Volume Not Working
Alright, Iāve been testing this as well, as I had inconsistent issues - Iāll just ping the last PD employee that really took a look at this issue and reported on it: @SarahChandler
Phone: Samsung Galaxy S20 5G
One UI: 3.1
Android: 11
PD app version: 6.53.1 (12039)
For all tests, I have PD set up on my work profile. However, I also have it downloaded on my personal profile, but itās not set up in any way.
The PD contact is also favourited/starred on the work profile, and āAutomatic Contact Card Managementā is enabled.
Additionally, the PD app āHU Override System Volumeā & āHU override Do Not Disturbā settings are both enabled.
For each test, Iām manually creating a new high urgency incident, and leaving the phone untouched until the first phone call should be made.
Baseline - Sound at lowest volume & DND off
This is the base use-case where sound should always work, given the phone has sound enabled.
- System volume on sound & vibrate;
- Volume at lowest non-zero value;
- Do Not Disturb mode disabled;
- Notify app immediately;
- First call to personal & work phone after 1 minute.
As expected, PD & calls worked fine this way.
This of course makes sense, since sounds are on globally for the whole phone. If PD didnāt work in this situation, Iād be very concerned.
Still, it is important to set a baseline, and confirm it indeed works as we expect it to.
#1 - Desired use-case: Vibrate & scheduled DND turned off during most hours
This is how I want PD to work on my phone, and these parameters will be the base of the rest of my tests.
- System volume on vibrate only;
- Volume at 0;
- Do Not Disturb mode disabled (scheduled to turn on at night, however);
This did not work as expected.
The PD App notification correctly caused the phone to vibrate + make a sound.
However, the phone call only caused the phone to vibrate.
#2 - Vibrate & Do Not Disturb enabled
- Volume at 0;
- Do Not Disturb mode enabled;
This worked as expected.
The PD App notification triggered both vibration and a sound.
The phone call also caused the phone to vibrate, and the ringtone to be played.
#3 - @max.2 's solution, with a phone call immediately being made, Vibrate & DND off
- Volume at 0;
- First call to personal & work phone *immediately.
This did not work for me, unlike what @max.2 reported.
Notification did vibrate + make sound.
Call only vibrated, just like before.
#4 - @max.2 's solution, with a phone call immediately being made, Vibrate & DND on
- Volume at 0;
Test successful, just like #2.
PD App notification vibrated + made a sound.
PD phone call vibrated + made a sound too.
So once again, DND seems to have to be on, and the time when the call is made does not matter.
Conclusion
It seems that DND mode is the key to the issue here. With this (limited) testing it is clear that the āHU System Volume Overrideā setting only works if the phone is also in DND mode.
Oddly enough, PD App notifications always make sounds just fine, regardless of if DND is on or not. Thus it seems this is an issue moreso related to starred contacts/phone call ringtones in general, rather than notifications overall.
The fix proposed by @max.2 did not work for me, and without DND enabled, this āimmediate-callā approach still did not work for me to create sound. So once again, DND mode having to be enabled for system volume override to work seems to be the problem at hand.
Retrospect
As stated in the desired use-case, I now run my phone on a schedule, to turn DND mode on during the night, because of this exact problem with PD. However, eventually, I just want DND mode turned off fully again. Itās simply a compromise Iām willing to live with for now, so I at least get woken up at night if a HU alert comes in.
DND seems to have to be enabled in order for PDās calls to make a sound if the phone is in silent or vibrate-only mode.
However, during the day, I donāt want DND mode turned on, so this still results in calls only vibrating during the day (as I do want my phone to run in vibrate-only). Of course, Iām more likely to notice the vibration during the day, when Iām awake, but this is still very problematic.
I donāt want to be required to run my phone with DND turned on or with the volume turned on during the day, to fix thus.
I simply want my phone on vibrate-only during the day, and only have PDās app & calls to override the volume and make a sound, so that all other notifications (e.g. chat messengers) & calls on my phone stay silent and just vibrate.
I hope my tests and reporting can help the PD team to pinpoint the problem and resolve it. This issue has been running for much over a year now, and although I understand this probably has to do with a lot of possible brand + android version combinations, I do see this as a very urgent thing to fix.
Facing the same issue with my Samsung Note 8. I restarted the phone but still facing the issue. Then i checked this https://geniusgeeks.com/volume-automatically-goes-down-android/ guide and finally managed to fix the issue.
If your Android phone automatically goes to Silent Mode, simply remove any āscheduled Do not disturbā settings on your Android device.
I still have the same issue mentioned in the thread ā calls do not trigger sound, even though āHigh-Urgency Override System Volumeā is true in the settings. Iām on a Pixel 7. The issue is only for calls, not notifications.
This is extremely HIGH PRIORITY to me, since it will cause me to miss a page.
I searched on every forum on internet and eventually end up fixing this by enabling the call waiting feature.
this is a crucial issue for Android users, especially those who rely on high-urgency notifications. Itās frustrating when such a feature doesnāt work as expected. On a related note, if youāre seeking a seamless mobile experience, consider reaching out to a reputable custom iPhone app development company. They can help create tailored solutions that not only work flawlessly but also enhance your user experience. Solving this Android 10 bug is a must, but in the meantime, exploring alternative options might be worth considering.
I am have this same issue with alerts and the Pagerduty Contact Card not overriding vibrate only on my Pixel 6.
Hello @jon.trainor,
Iām sorry your facing this issue
If you havenāt done so, please message the support team here so they can work on your case.
I just switched to Pixel 7a, and already missed two notifications as it no longer overrides vibrate+DND. How is this still an issue??
